Show Region not working
I'm trying to show a basic text if a column is value is equal to New and this doesn't work. It would show the text even if the value is not equal to New.
The security assist show region behavior cannot be used for recordset values.
you need to use the Show region Utility instead.
open the server behaviors panel, click the plus button and select WebAssist -> Utilities -> Show region Utility.
Unfortunately there are only two section under WebAssist -> Utilities -> Server Redirect and Set Server Timeout.
What extensions do you have? The Show region Utility is included in Data Bridge.
if you don't have data Bridge, it will need to be hand coded.
for example:
if ("".$row_recordsetName['ColumnName'] ."" == "New") {
show text
