Help getting a Session Var from the #2 Insert Record Behavior ?
Thread began 10/20/2012 12:03 am by sjones435326 | Last modified 10/22/2012 1:12 pm by sjones435326 | 516 views | 2 replies |
sjones435326
Hello I have a form that is submitting data into two separate tables. It is working great, but I’m having a little difficulty on the redirect of the second insert records behavior
In the first “Insert Record” I have
<- FIRST INSERT RECORD ->
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $********;
$WA_table = "companies";
$WA_sessionName = "companies_company_id";
$WA_redirectURL = "";
So I have the redirectURL blank, and then I’m passing the $WA_sessionName down to the next “Insert Record” like this.
<- SECOND INSERT RECORD ->
$WA_connection = $connect1;
$WA_table = "locations";
$WA_sessionName = "WADA_Insert_locations";
$WA_redirectURL = "locations_Detail.php?location_id=".$_SESSION['WADA_Insert_locations'] ."";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "location_id";
$WA_fieldNamesStr = "status_id|company_id|rep_id|location_type_id|location_name|address|city|state|zip|phone|fax|contact_person|contact_title|contact_person_phone|contact_person_phone_ext|conatct_person_alt_phone|contact_person_email|alt_contact_person|alt_contact_person_phone|alt_contact_person_ext|alt_contact_person_email|follow_up_status_id|follow_up_date|square_foot|utility_provider|website";
$WA_fieldValuesStr = "".((isset($_POST["status_id"]))?$_POST["status_id"]:"") ."" . "|" . "".$_SESSION['companies_company_id'] ."" . "|" ……….And so on ……
My problem is this, after the 2nd Insert Record the redirect URL is returning a NULL result and I’m getting an error like this
“You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1”
Because the location_id is coming back empty.
What I’m trying to do is to populate the URL so I can then go directly to the Detail page of the account that was just created.
Any Ideas?
you dont need to pass the session as part of the URL variable, the whole idea of using a session is that once set, it is available to all pages.
in the locations_Detail.php page, set the recordset to use the $_SESSION['WADA_Insert_locations'] variable instead of trying to pass it through the URL.
if you continue to have problems, send a copy of both the insert and details pages in a zip archive so i can see the entire page code.
sjones435326
Hello Jason, first of all I'm sorry that I wasted your time. After I read your post, I went to the location_Detail.php page and looked at the code. This bit of code was already there.
$ParamSessionlocation_id_WADAlocations = "-1";
if (isset($_SESSION['WADA_Insert_locations'])) {
$ParamSessionlocation_id_WADAlocations = $_SESSION['WADA_Insert_locations'];
I am unsure how that got generated, but I'm assuming that the DATAAssist Wizard had something to do with it.
I went back into the insert pages and changed the redirect from the second insert behavior to the basic URL "locations_Detail.php" and sure enough it functioned perfectly.
I first of all want to thank you for thinking of these features and making things so much easier.
I feel like an idiot for wasting three days trying to make things more complicated by sending the variable through the URL, when all I had to do is set the redirect to the details page and it was ready to go. Okay, live and learn. I'll try not to waste anymore of your time!
