Checkout Wizard Bug?
Thread began 10/19/2012 9:33 am by Mike Perry | Last modified 10/20/2012 9:26 am by Mike Perry | 364 views | 2 replies |
Mike Perry
Created the Checkout page and added the Checkout button. Then ran the Checkout Wizard. Wizard runs, but then the eCart Checkout button in the Server Behaviors panel has the red exclamation point. In reviewing the code, the first line of the <head> PHP code is this:
if (isset($_POST["ccds_Checkout_1"]) || isset($_POST["ccds_Checkout_1_x"]))
And the button code is this:
html:
<input type="submit" class="eC_FormButton" value="Checkout" name="ccds_Checkout">
Changing the button code to this clears the exclamation point
html:
<input type="submit" class="eC_FormButton" value="Checkout" name="ccds_Checkout_1">
I re-ran the process (add button and then Checkout Wizard) -- the Wizard drops the '_1' in the button code.
eCart version 5.06 -- all other extensions current, including Design Extender and Data Bridge. eCart was installed prior to the other two. Windows 7 Professional 64 bit, CS6 Master Suite.
I am not able to reproduce this problem, i will keep trying to find a cause for the problem though.
Mike Perry
I'll retry this in a new page to see if perhaps this was just a one time hiccup.
ETA: Just tried with a test page -- no problem. Must have been a one time issue. . .
