Access rules
Thread began 10/12/2012 9:40 pm by 3dmikec442988 | Last modified 10/18/2012 12:24 pm by 3dmikec442988 | 875 views | 6 replies |
3dmikec442988
Access rules
How do I create a "user logged in" rule in the Access Rules Manager? I'm trying to create a dynamic button that reads "Login OR Register" if the user is logged out and if the user is logged in the button reads "Logout OR Account".
after running the security assist, the Access rules manager will create a rule named "logged into <your user table>" (where <your user table> is the name of your user table. this rule is used to determine if the user is logged in.
you can use the Security assist show region to show the Login or Register button if the "logged into <your user table>" rule is false, or the LOgout and account link if it is true.
3dmikec442988
Ok so I ran security assist and it made the rules and I applied these to my button which I incorporated into my template. But I'm running into some problems.
First, when I complete the registration form, it takes me to the log in page and says "REGISTRATION COMPLETED SUCCESSFULLY, PLEASE LOG IN TO ACCESS THE SITE". However, my buttons already read "LOGOUT" and "ACCOUNT". It seems completing the registration logs the user in automatically.
Second, when I hit my "LOGOUT" button, it takes me to the log out page and says I was successfully logged out, but my buttons still read "LOGOUT" and "ACCOUNT" unless I either hit the log out button again or go to another page.
Yes, the registration sets the logged in session variable.
if you would rather not have that happen, edit the insert record behavior on the registration page, in the Save inserted ID in session section, change the name of the session that will be created.
Send a copy of the logout page so i can look into why the messages are displaying incorrectly.
3dmikec442988
Thanks for the help. I zipped the .php file. I hope this is the proper procedure.
logout.zip
the problem is that the code to clear the sessions and log the use out is at lines 61 - 78
@session_start();
if (
// WA_ClearSession
$clearAll TRUE;
$clearThese explode(",","");
    if(
$clearAll){
        foreach (
$_SESSION as $key => $value){
            unset(
$_SESSION[$key]);
    else{
        foreach(
$clearThese as $value){
            unset(
$_SESSION[$value]);
move that code to line 1.
3dmikec442988
That makes sense. Thank you.
