Learn how to build a better order detail page video tutorial
Thread began 10/11/2012 5:45 am by dvan_zelst | Last modified 10/11/2012 7:01 pm by dvan_zelst | 759 views | 2 replies |
dvan_zelst
In the video tutroial "Learn how to build a better order detail page" after adding the order detail page as a plugin with Framework Builder you add some extra code for security if you want to use it in the front end.
Add the beginning of that code you use $GET, should this not be $_GET?
do you mean the "Display relational table data with plugins" tutorial?
I dont see a tutorial named "Learn how to build a better order detail page"?
what is the time marker in the video where this happens?
dvan_zelst
Hi Jason,
Yes the video tutroial is called: Display relational table data with plugins
At timeframe: 12:20 ~ 12:30 you used $GET instead of $_GET.
:-) Guess you already marked it in the tutorial.
No more comments then.
