Amending User Registration with Security Assist
Thread began 8/06/2009 2:41 pm by mds119803 | Last modified 8/07/2009 10:48 am by Eric Mittman | 1348 views | 1 replies |
mds119803
Hi, I recently purchased User Registration and implemented that into my site. I then bought Security Assist as I need to have different users access different areas. I am having a problem getting SA to work with the existing user_ forms that were created by User Registration Solution Pack. It seems that they 'add' the code that the SA wizard creates to the existing forms rather than amend them. I am therefore ending up with duplicates on each page. I thought I had just done it wrong at first but then ran the wizard again and ended up with yet another set of code within the user_ set. It's consequently getting very confused (as am I) and now crashing my system regularly. The crashing also started once I had put the forms into my templates but I am not sure if that is coincidence as I have been trying to get this to work now for many hours and have had a very frustrating time of it! What am I doing wrong or is it simply that you just can't run the wizard again?
When I implement the SA site features from the modify menu that seems to work ok and remember my settings but the wizard just seems to start from scratch each time. Thanks
You will not want to use the wizard again as it is not re-entrant. It will only create the new pages for you with the code, it will not update the existing server behaviors on the pages.
To make adjustments to the pages you should open them up and edit the individual server behaviors. To make different access levels you should be making edits to the access rules and the user authentication on the login page.
The Access Rules manager is available from the modify menu. Please post back with more detail about the specifics of what you are trying to accomplish.
