Update button reloads page
Thread began 10/08/2012 7:30 am by htm2112 | Last modified 10/08/2012 5:16 pm by htm2112 | 630 views | 1 replies |
htm2112
Well, I'm sure this is simple but I cannot find the answer. I have used DataAssist a number of times but never had this problem. For some reason, when I click update, the page reloads and updates the record but does not go back to my results page. If I click cancel, I get to the results page and see that the record was updated. I have the field set with the new page to go to on update, but it won't go.
Same things happens on insert, and delete. It will insert the record but not go back to results page. And on delete, it will delete the record but not go back to results.
I have gone so far as to rerun the wizard back to vanilla settings, but this problem remains. Can you check out this code and see if something is wrong?
staff_Update.zip
htm2112
I figured it out after scouring through all the posts on this. Apparently you have to comment this line out, like this:
// if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
I have no idea what this is all about, but at least it works now.
