Image Upload - append image with a session name
Thread began 10/04/2012 11:43 am by Suggs | Last modified 10/04/2012 12:41 pm by Jason Byrnes | 722 views | 1 replies |
Suggs
Hi folks,
Can you point me in the right direction.
I have created an image upload where the person can go in and upload their image, however i need it to append the image name with a session variable.
Basically 8 stores are going to go in and upload their images and these images need to identify the store from their login session name.
make sure that the session is listed in the bindings panel under the session collection.
then in the upload behavior, for the File setting, the Default will be set to "[FileName]". click the lightning bolt icon and select the session variable from the binding panel, then past "[FileName]" after the binding code so the File setting looks like:
<?php echo $_SESSION['sessionName']; ?>[FileName]
