Login/Logout Show Region not working
Thread began 10/03/2012 9:38 am by s.joiner74419001 | Last modified 10/04/2012 11:48 am by Jason Byrnes | 848 views | 3 replies |
s.joiner74419001
I have a div tag holding three links - Register, Login, Logout. I have used a "show region behaviour/ Logged in to users access rule" with the Logout link so it only shows when users are logged in. This part works as once logged in it appears. But when I click to logout this error message appears on the logout page in the div tag .
Fatal error: Call to undefined function WA_Auth_RulePasses() in /Applications/MAMP/htdocs/team_root/logout.php on line 80
What's Happening here?
Please Help.
send a copy of the logout page please
s.joiner74419001
I have attached the Logout page in a zip file. I have discovered that the div tag that holds the three links is whats causing the error. I created a new template that didn't have the div tag included and it works. But this defeats my issue as I want this div tag to be shown as in theory it would have the register link and login link displayed. Maybe this is not normal practice to have, but neither is creating a template just to use on one page.
Hope this helps!
Cheers Jason!
logout.php.zip
your page is missing the require_once line to include the security assist helper file.
add the following code at line 1:
<?php require_once( "webassist/security_assist/helper_php.php" ); ?>
