registration format
Hello again.
I will need to change the css colors and page look general for the registration.
also to put my logo and ....
Where can i find those files so i can make the changes that i like?
thanks a lot for your help.
Hello again.
in the webassist/themes folder, there is a subfolder for each theme.
open the subfolder for the theme you are using.
In the css folder for the theme are all the css files to control the design.
it may be helpful to use Fire Fox and Fire Bug to inspect the elements of the page you wish to edit to find the css classes that control those elements more easily.
