CMS -> Add content to PowerCMS
When I add content to PowerCMS the script adds this line
<?php require_once("WA_CMS/WA_CMS.php"); ?>
NO folder is then created containing such file
Any solution?
Any solution?
have you refreshed the 'files' window in dreamweaver as once pcms is installed, there should be similar in structure to the attached image....as you can see there, there is a folder called 'WA_CMS'
the structure cannot be like your picture because i already have an index.php that belongs to the site so i must keep powercms in it's own folder.
surely you guys must have thought of that??
firstly, when you say 'you guys' I am just a user like yourself...am just trying to help out.
now, the index.php file in my image is one that I created myself and isnt created by the PCMS installation....
If you keep the PCMS structure within the powercms folder that you have created (which I wouldnt recommend) then you would need to edit the path in
So where you currently have
to reflect where that is being found in relation to the root...
So, you could try
<?php require_once("powercms/WA_CMS/WA_CMS.php"); ?>
I hope that this helps.
Power CMS builder will add the files to the root of your site.
I recommend adding Power CMS to your site as the first step.
Try deleting the PowerCMSConnection file from the Connections folder and adding a new content area to trigger creating the files.
