available_columns, keyCol) has no properties
Thread began 10/01/2012 5:31 pm by kbettenc296716 | Last modified 11/21/2013 4:41 am by Daryl | 1970 views | 6 replies |
kbettenc296716
I am getting the error message others have received. line 2049 "c:\Program Files\....GetAvailableColumnByName(wa.dataassist_settings.available_columns, keyCol) has no properties.
I have reset my workspace, downloaded and installed the new page generation js file, and deleted the .dat file. It doesn't make any difference. Databridge creates the _insert page, starts on _update and then I get the error message and DataBridge hangs.
Can you give some details on the application settings you are using in the Create pages wizard and the structure of your tables please?
kbettenc296716
Here is the info, connection and .sql plus image of page 1,2,3 on databridge
$hostname_conArtists = "localhost";
$database_conArtists = "ldgartists";
$username_conArtists = "root";
$password_conArtists = "autumn0";
-- Create schema ldgartists
CREATE DATABASE IF NOT EXISTS ldgartists;
USE ldgartists;
-- Definition of table `artists`
DROP TABLE IF EXISTS `artists`;
CREATE TABLE `artists` (
`ID` int(11) NOT NULL auto_increment,
`QBCode` varchar(50) default NULL,
`FirstName` varchar(255) default NULL,
`LastName` varchar(255) default NULL,
`Inactive` tinyint(1) NOT NULL default '0',
`StudioNumber` varchar(10) default NULL,
`StudioName/Company` varchar(100) default NULL,
`Address` varchar(100) default NULL,
`City` varchar(60) default NULL,
`St` varchar(2) default NULL,
`Zip` varchar(10) default NULL,
`HomePhone` varchar(20) default NULL,
`CellPhone` varchar(20) default NULL,
`WorkPhone` varchar(20) default NULL,
`PrimaryEmail` varchar(60) default NULL,
`SecondaryEmail` varchar(60) default NULL,
`Website` varchar(60) default NULL,
`Bio` text,
`Image1` varchar(60) default NULL,
`Image2` varchar(60) default NULL,
`Image3` varchar(60) default NULL,
`Image4` varchar(60) default NULL,
`CheckTo` varchar(100) default NULL,
`NameArtwork` varchar(100) default NULL,
`Media` varchar(255) default NULL,
`PrimaryMedium` varchar(255) default NULL,
`SpecialHandling` varchar(255) default NULL,
`2DMaximumSize` varchar(100) default NULL,
`3DSize` varchar(255) default NULL,
`DayJob` tinyint(1) NOT NULL default '0',
`TeachGSSummer` tinyint(1) NOT NULL default '0',
`PrecludeSitting` varchar(255) default NULL,
`VolunteerSkills` varchar(255) default NULL,
`ShowInterest` varchar(100) default NULL,
`ShowReady` varchar(60) default NULL,
`Show1` varchar(100) default NULL,
`Show2` varchar(100) default NULL,
`Show3` varchar(100) default NULL,
`Show4` varchar(100) default NULL,
`LastModfied` datetime default NULL,
PRIMARY KEY (`ID`),
KEY `Code` (`Inactive`),
KEY `QBCode` (`QBCode`)
) ENGINE=MyISAM AUTO_INCREMENT=48 DEFAULT CHARSET=latin1;
StudioName/Company is not a valid name for a table column.
column names can contain only letters and numbers, the "/" character is not allowed in column names.
kbettenc296716
No luck
Thanks for catching that, that was dumb on my part. However, it didn't make any difference. I still got the same error.
DarylBeta Tester
This post has been deleted.
