final fixits, two
Thread began 10/01/2012 11:40 am by zinlover320832 | Last modified 10/02/2012 1:31 pm by Jason Byrnes | 570 views | 4 replies |
zinlover320832
final fixits, two
Hi Jason:
PowerStore/
Two fixits:
1. The heading "Our Guarantee" in the middle pod is positioned lower than the headings on the left and right pod.
2. on the "Programs" pod there are two left tag brackets that need to be removed:
Our self pacing programs include: Math; Language; and Visual Perception.
3. for gateway / authorize.net, what fields need to be filled in
4. on the bottom footer, how do I add another link?
Thank you very much,
Stuart
zinlover320832
four small fixits
Hi Jason:
PowerStore/
Two fixits:
Stuart
1) See this thread for details on fixing this:
showthread.php?t=23342
2) It looks like you have some news content pages set in the Content Management section that contain only "<", you will need to remove those from the Power Store CMS.
3) For Authorize.net, you need to set the Login and Transaction Key. None of the settings under the 3D Secure section are required
4) edit the webassist/plugin/cms_templates/footer.php page
zinlover320832
3/4 finished with fixits
Thank you Jason:
I looked in the CMS both in view and source. There were no "<".
Stuart
i'd need to see the admin contents to troubleshoot.
