Workflow for admin pages
Thread began 9/30/2012 10:06 pm by dvan_zelst | Last modified 10/01/2012 9:23 am by dvan_zelst | 670 views | 2 replies |
dvan_zelst
Just a simple question:
I need to create a lot of custom administrative input pages. Normally i would use databridge pages manager and create all the results and insert pages from there. However this way i can only choose a form design which i created using form builder tool but it does not let me create the form layout.
My question is what procedure to follow best. Using above or designing every form with form builder tool and then create all the insert and update behaviors manually with the databridge insert and update behaviors etc.
I really would like to have control over the input form layouts for every form i need to create and not just the overall design look only.
Thanks for the advice.
to have the control over the form layout you are asking about, you will need to create the forms using Form Builder, then manually apply the server behaviors to the pages.
dvan_zelst
Thanks Jason,
I'll play around a bit first to see where it takes me.
