DataBridge for CMS - how to put content into webpage?
Thread began 9/30/2012 9:25 am by brendafos379366 | Last modified 10/01/2012 1:40 pm by Jason Byrnes | 1199 views | 3 replies |
brendafos379366
I used to use PowerCMS. I just got DataBridge and I have it working.
But I don't understand how you are suppose to place the content into specific webpages? I do not see instructions related to DataBridge for CMS.
I assumed that you put a tag in a webpage which call the content from the table, but how do you do that?
Maybe I should have stayed with PowerCMS. Can I have both installed in DreamWeaver?
Data Bridge does not contain Power CMS Builder.
Power CMS Builder is a part of Design Extender.
You will either need to install the power CMS Builder extension, or install Design Ext3ender which contains Power CMS Builder.
brendafos379366
OK, but the other part of the question - once I've made the DataBridge CMS tables and the pages to insert/update/search/details - how do I then put that content into viewable webpages?
you would need to create a recordset on each page to return the content, then use that recordset to display it.
