Advanced Searche brstallion
I want to be able to do an advanced search.
Search all the pedigree fields ie Sire, Sires, Sires, Sires Sire Sire, Dam.... verses just one of the pedigree. brstallion_search.php
In the data assist search server behavior, you can set a criteria to use more than one column from your table.
The column select list is a multiple select list, You can select all of the database columns that a single criteria should search
