Padding wont work!
Im trying to create a menu where the boxes are separated and it works when the dimensions of each box are 241 pixels but not when they are 157 like I need them to be!
What category and theme are you starting with?
that menu type uses images for the background that have a preset width.
after the menu is created, you will need to edit the background images to use the width you want you menu to be.
How would I do that? How would I know what width the image is?
after the menu is created, open the CSSMenuWriter folder. there will be a folder under this for your menu images.
in that folder edit the 2 background image to change the width to match the width you are using for the menu items.
