Another Issue missed in the updates
Thread began 9/25/2012 11:53 am by Jared Lui | Last modified 9/25/2012 12:41 pm by Jason Byrnes | 370 views | 1 replies |
Jared Lui
I think Jason's fix to this issue
showthread.php?t=27115
should be added as a permanent solution as this is still happening in version 1.1.1 and the fix still corrects the issue.
Thanks,
Jared
it's not so much that this issue was missed in the updates. It;s as designed. More often than not, the p tags should be added around the HTML Editor content. the more common scenario is to start a new paragraph when the enter key is used.
I will add a feature request though to have the engineers consider adding a selection to the HTML Editor interface to choose between using p tags or br tags
