Listbox problem
Hi
I have a listbox on 2 forms the insert and update forms. The value returned from them is an array which I dont want I need it to return the value of ApriorityID which is a field in a table called Aprority. The list box displays as a multi select and I was hopping just for a drop down single selection, the problem is with multi select returning an array, is there a way to make it drop down and just return the value I require. (I used the wizard to create the attached pages)
Thanks for your help
Keith
