Session not set by mysql_insert_id()
Hello,
Can't figure this one out. Insert record works but the session is not set from the query. Works fine on other pages. File attached.
Thanks for the help.
Hello,
your using the wrong session variable in the manage relational table behaviors.
line 118:
$WA_sessionName = "WADA_Insert_Print";
sets the name of the session as "WADA_Insert_Print".
In the manage relational table behaviors, you are binding to the session named "WADA_Insert_print". Note the lower case p. PHP is case sensitive.
change line 118 to use a lower case p:
$WA_sessionName = "WADA_Insert_print";
