getAvailableColumnByName error
Thread began 9/24/2012 1:34 pm by aidanwynne5442402 | Last modified 9/25/2012 10:32 am by Jason Byrnes | 607 views | 1 replies |
aidanwynne5442402
Trying to test out a CMS and this happened.
While executing timer in WA_SiteTools_ProgressV2.htm the following Javascript error occurred:
At line 2049 of the file
"C:\Users\Aidan\AppData\Roaming\Adobe\Dreamweaver CS6\en_US\Configuration\Floaters\WA_SiteTools_ProgressV2.js" getAvailableColumnByName(wa.dataassist_settings.available_columns,keyCol) has no properties
I tried deleting the .dat file by the way and no difference.
There is no line 2049....only 527 lines and no mention of getAvailableColumnByName.
What gives??
EDIT: Ok I figured I had no primary key and that solved it.
While I am here how do I get rid of the ? icon in a dimaond appearing on in the update box instead of the >> ' <<
I'm not sure i follow, can you post a screen shot please.
