HTML editor in databridge
Thread began 9/21/2012 5:12 am by mrs | Last modified 9/21/2012 8:32 am by Jason Byrnes | 1057 views | 1 replies |
mrs
I'm not sure if the dataassist wizard has acted as it is meant to or not. I have just created the usual pages with it (search, results, detail, insert and update), and within the wizard I selected that two fields should be HTML Editor fields, but they aren't, they're just standard, medium-sized text fields!
Is this meant to happen so that we then have to manually add the html editor via the webassist menu, or should the wizard have done it automatically?
I assume I can add HTML Editor myself without it breaking, but I just wanted to ask if ending up with a standard text input box is correct behaviour or not?
Thanks.
Mat
If you set them to be HTML Editor fields in the Field Settings section of the Data Assist wizard, they should be created as HTML Editor fields on the Insert and Update pages.
Make sure you have the latest version of Data Bridge (1.0.8) Installed, if you have a previous version, make sure to uninstall it from the extension manager before installing the newer one.
