RGBA color mode
Why can I not select color from RGBA in Menu writer?
I want to create a transparent background. Now I have to change this in the css file manually. This is not good, then I have to do this every time I change in the menu-writer.
No, the css menu writer wizard does no have a selection to use the RGBA color palette.
If you are making changes to the CSS outside of the wizard, you should create a new css file to define those changes in so the menu writer wizard wont over write them.
By using a new css file to make your changes to what is produced by the wizard, the wizard wont be able to over write them if you make edits.
