Adding a chosed "CC" email recipient
Thread began 9/18/2012 1:56 pm by rgolab68503 | Last modified 9/19/2012 9:32 am by rgolab68503 | 990 views | 2 replies |
rgolab68503
Hi There,
I have been trying to get the email notification to go to a selected person by the person placing an order inquiry.
In the checkout page i have a dynamic drop down menu where they chose their sales rep. The information is received on the confirm page. It then try to add it to Universal Email. For some reason this information is not being transfered over.
Could you help please. Not sure where i am going wrong here. I have attached the pages along with the wauve_confirm file Universal Email seems to be attached to.
Emailing_CC_not_working.zip
for any form element that you add to the checkout page, you need to add a hidden form element of the same name to the confirm page that will capture the value posted from the checkout page, and also add a set session value behavior to capture the value.
on the confirm page, there is a collection of hidden form elements. add another one using the same name as the select list and set the value to capture the selected element on the checkout page:
<input type="hidden" name="toyorep" id="toyorep" value="<?php echo ((isset($_POST["toyorep"]))?$_POST["toyorep"]:""?>" />
then go to the server behaviors panel, click the plus button and select eCart -> General -> Set Session Value
for the trigger select any form post.
Set the name to toyorep
for the value, click the lightning bolt icon and select the toyorep form element.
now in the Universal Email behavior, set the CC option to use the toyorep session variable.
rgolab68503
That did it. Thanks. I thought that creating a separate session variable i could make it work. I had the email transfereing to the page but didn't make it to Universal Emailer. Thanks again.
