Changing Hosting Providers
Thread began 9/11/2012 3:56 am by cymbalroad | Last modified 9/11/2012 9:48 am by Jason Byrnes | 391 views | 1 replies |
cymbalroad
Hi there
I have moved my site I had set up from one hosting provider to another and just want to confirm is there anything from your end that needs to be done due to the registration process ?
All I have done is go back through the script installation procedure with my new hosting provider and then I plan to just copy across the relevant SQL files over the next few days that are needed for the products etc I already have loaded, but I'm not sure if there will be an issue with my registration code ?
If there is an issue do I need to have you de-activate my original registration so it records I only have the one site, as the original site was setup for cymbalroad.com where is the new site is cymbalroad.com.au.
Cheers
Nigel
there shouldn't be a problem, i deleted the activation for cymbalroad.com from our system for you.
