Databridge Crashes Dreamweaver CS6
Thread began 9/10/2012 7:56 am by q_carlos322496 | Last modified 9/10/2012 10:38 am by q_carlos322496 | 1915 views | 4 replies |
q_carlos322496
When I attempt to use the Databridge - WebAssist - Database - DataAssist Pages interface and begin to make a selection Dreamweaver CS6 crashes.
I've uninstalled every extension and repaired the CS6 installation, then installed databridge again and while it happens less often, it still happens.
I am using Mac OS X (10.8.1), iMac with a 3.4 GHz Intel Core i7, 16GB RAM - Adobe Master Collection CS6 with all the available updates - Databridge version is 1.0.7
Second issue - at dreamweaver cs6 startup i get an error referencing an old webassist extension - I've attached the screenshot.
pdf of the crash report is attached.
Process.pdf.zip
What other extensions do you have installed including version numbers?
q_carlos322496
other installed extensions
Design Extender 1.1.0
WebAssist Free Tools 1.0.0
Surveyor 1.0.8
Go to WebAssist -> Preferences in the Memento section Set the Show in dreamweaver option to Never.
In the RSS Section, check the option to disable all RSS Feeds and Check For Updates only when Memento opens.
Then go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
q_carlos322496
RSS Error Fixed
That fixed the RSS Error. Thanks!
