struggling to understand a rule.....
Thread began 9/10/2012 10:31 am by JamieEff | Last modified 9/10/2012 12:02 pm by Jason Byrnes | 932 views | 3 replies |
JamieEff
Hi Jason
Am trying to set up a simple 'check a code' which then takes a visitor to a page which will then tell them if they have won or not.
The code is predetermined 7 digit and have set up the database with a table called comp (see attached) with a column in it 'compcode'. Am not sure if I have done it right??
On the result page I have 2 content sections, one if you win and one if you dont win
I have set up the access rules 'Winner' and 'NoWin' (also attached) but its not working for me and I know I have done something wrong, I just dont knwo what....
Thanks in advance
Jamie
your rule makes no sense.
you are comparing the session to itself. This will always return true.
the session "compcode" will always equal itself.
you need to use another comparison.
how are you determining if the user is a winner or not?
how does the session compcode get set?
JamieEff
a 7 digit code and as my experience and skill is very limited, I am setting it so that the visitor has to enter a code that they have received.
This then takes them to the reult page which will show the relevant content subject to them being a winner or not.....
I will be doing this manually by changing the winning code in the database
So you are sending them an email with the code, and you then have a form where they enter the code?
Ok, so on the form page add a recordset to look up the code in the database.
then add a set session value behavior to the page to set a session named "WinningCode"
For the value, click the lightning bolt icon and select the code column from the recordset.
add a second set session value behavior to the page, for the trigger and the value, click the lightning bolt icon and select the code form element.
Set the name to EnteredCode
In the Rule, use the WinningCode session as the Value, and the Entered code session as the Comparison
JamieEff
I think I have created a recordset doing what you say.... (please see atatched)
I have no idea how to add a set session value behavior to the page and to which page I would add it......
Do I still need to authenticate the user or is this replacing that on the submit page?
you need to filter the recordset using the code column and a Form Variable.
in the Filter section of the recordset, select the code column "=" "Form variable" then enter the name of the text box on your form.
the set session value behaviors should be added to the form page.
open the server behaviors panel, and click the plus button, select webassist-> Cookies -> Set Session Value.
JamieEff
thanks...
I have added the session
if (!session_id()) session_start();
if(!isset(
$_SESSION["WinningCode"]))     {
$_SESSION["WinningCode"] = "".$row_CompRS['compcode']  ."";
if(!isset(
$_SESSION["EnteredCode"]))     {
$_SESSION["EnteredCode"] = "".((isset($_POST["code"]))?$_POST["code"]:"")  ."";
Not sure if I have done it right?
The recordset is attached... am not sure if that is right either.
What do I do with the form and submit now? How do I get from the code entrry to the reult page?
On the results page I have added a rule which doesnt seem to be working - see attached
Jamie
Do I still need to authenticate a user?
the rule should be configured to use the session variables that you created, not the form post or the recordset.
the point is to set a session with the winning code. In my previous reply, i suggested filtering the recordset, but that was not right. The recordset should not have any filtering, sorry about that.
and set another session with the entered code.
this is done by creating a form with a text box in it and using the set session value behavior to capture it.
In the rule, you use the 2 sessions for comparison to see if they match.
if they do, then the user entered the right code.....
