Datepicker does not work!
Thread began 9/09/2012 9:05 am by Noa2086 | Last modified 9/11/2012 9:35 am by Jason Byrnes | 947 views | 1 replies |
Noa2086
i would like to insert a datepicker but after inserting it's nothing happening. i inserted a custom jquery theme.
my files included:
2 jquery files:
<script type="text/javascript" src="../webassist/jquery/jquery.js"></script>
<script type="text/javascript" src="../webassist/jquery/jquery-ui.js"></script>
1 datepicker css:
<link type="text/css" href="../webassist/forms/fd_likebeyond_normal/Datepicker/css/jquery-custom.css" rel="stylesheet">
seond problem: error at dreamweaver startup
error: on line 2 of file ../WebAssist/GoogleToolkit/shared.js "wa" is not defined.
any ideas? thx for helping.
Can you post a link where i can see the problem to investigate the cause.
The error "wa" is not defined happens when you are using older stand alone extensions along side the newer bundled extensions like Design Extender or Data Bridge.
It is really just a nuisance error and should not effect functionality. If you are not getting other errors, you can ignore that one.
Noa2086
This post has been deleted.
The date picker uses jquery and attaches it to the page with the date picker:
$(function(){
$('#Datum').datepicker({
changeMonth: true,
changeYear: true,
onClose: closeDatePicker_Datum,
dateFormat: 'yy-mm-dd',
showMonthAfterYear: true
function closeDatePicker_Datum() {
var tElm = $('#Datum');
if (typeof Datum_Spry != null && typeof Datum_Spry != "undefined" && Datum_Spry.validate) {
Datum_Spry.validate();
var docElm = document.getElementById("Datum");
var tBlur = docElm.getAttribute("onBlur");
if (!tBlur) tBlur = docElm.getAttribute("onblur");
if (!tBlur) tBlur = docElm.getAttribute("ONBLUR");
if (tBlur) {
tBlur = String(tBlur).replace(/\bthis\b/g, "docElm");
eval(tBlur);
</script>
you are causing a jquery conflict by adding a second version to the page using this code:
<script src="//ajax.googleapis.com/ajax/libs/jquery/1.8.0/jquery.min.js"></script>
<script>window.jQuery || document.write('<script src="js/vendor/jquery-1.8.0.min.js"><\/script>')</script>
remove those 2 lines, and the date picker will work
Noa2086
Now it works, thx you jason!
gavind
Which line did you edit for this to work?
