securityassist forgot password problems
Thread began 9/07/2012 11:51 pm by velocityoptics428805 | Last modified 9/10/2012 7:56 am by Jason Byrnes | 770 views | 1 replies |
Having issues setting up the setting of the assistant in this case. Am receiving the following when I submit from the form:
Warning: Missing argument 6 for WA_SecurityAssist_Definition(), called in /home/content/b/o/s/boscorebec/html/forgotpassword.php on line 68 and defined in /home/content/b/o/s/boscorebec/html/webassist/security_assist/mail_php.php on line 34
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/b/o/s/boscorebec/html/webassist/security_assist/mail_php.php:34) in /home/content/b/o/s/boscorebec/html/webassist/security_assist/mail_php.php on line 239
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/b/o/s/boscorebec/html/webassist/security_assist/mail_php.php:34) in /home/content/b/o/s/boscorebec/html/webassist/security_assist/mail_php.php on line 239
Warning: Cannot modify header information - headers already sent by (output started at /home/content/b/o/s/boscorebec/html/webassist/security_assist/mail_php.php:34) in /home/content/b/o/s/boscorebec/html/webassist/security_assist/helper_php.php on line 140
Also, in the settings window I am simply unclear as to many of the settings. Primarily, I do not understand what "value" I should be pointing to? Thanks for considering my issues. M
In the forgot password server behavior, on the Email Settings tab, make sure to select a Character Set.
Well, it depends on the setting, and also the requirements of the Host.
for many Hosts, you can leave settings like the SMTP Server or Port blank. For other hosts, you may need to enter the correct SMTP server and port address.
Specifically, which settings are you unclear on? and who is your host?
