Server Reset Problem
Thread began 9/05/2012 9:40 pm by Mike Perry | Last modified 9/10/2012 3:45 pm by Mike Perry | 1067 views | 6 replies |
Mike Perry
Testing on a local server. Latest version of Design Extender/Data Bridge. Was working fine.
Now the Template file displays fine, but when I test index.php the server resets. Discover Files fails in Dreamweaver.
I can comment out "$WA_main_1345639051375_Template->Initialize(true);" on line 9 and Discover Files works in Dreamweaver. Obviously the page doesn't display properly.
Do I have an Apache problem?
Relevant files attached.
ETA: My Apache error log reports "child process exited with status 3221225725 -- Restarting" whenever I try to access the page.
ETA2: Found the problem. I had added an onFocus statement to the body tag in the Template to preload images -- removing that statement cleared up the reset.
lig.zip
so it sounds like you fixed you the issue?
Mike Perry
I found the problem --
It would be interesting to figure out why the combination of the onFocus statement and the Initialize function resets the server. . .
I have not been able to reproduce the problem, I would need to see the problem happening in order to troubleshoot it.
Mike Perry
If I get a chance I'll upload the site to a testing server you can access and see if it happens there.
Mike Perry
A little more info:
The server reset occurs when I try to preload more than 12 images.
Mike Perry
I tried the site on my server at pair networks -- no problem.
I suspect an issue with the way I have Apache configured on my local machine. Will have to investigate with Apache. . .
Thanks --
