HTML Editor Field deleting data on Update & Insert
Thread began 9/04/2012 5:06 pm by subscrpt236790 | Last modified 9/04/2012 7:03 pm by YellowCircleWeb | 422 views | 1 replies |
subscrpt236790
I updated a textarea field to have use HTML Editor from data bridge and now the data for that field doesn't make it to the database for both Inserting a record and Updating a record. the pages are pointing to the correct database and field... all other fields are update correctly, so I know that the editor enabled field is what needs correction.
What should I look at to find the issue?
Are there any known issues that commonly happen here?
YellowCircleWeb
Have a look at the ID or name of the HTML Editor field, make sure it's included in the insert/update queries. If you were using a different type of field before and it was working OK then it stopped when you replaced the field with a HTML editor field you will need to double check the name of the field hasn't changed. If it has then you will need to rename it to match the name of the original field.
Hope that helps you.
