CS Sculptor closing down.
Thread began 9/04/2012 3:11 am by tony363743 | Last modified 9/04/2012 12:19 pm by Jason Byrnes | 357 views | 1 replies |
tony363743
Hi
I am using CS Sculptor 3.0.2 on a PC running Windows 7 Home Pro. The program is shutting down with no warning. I select a template and colour scheme and click edit in the usual way. I will then spend a fair bit of time editing the template to the customers design when, without any warning, CS Sculptor just closes and I lose everything. Any clues anyone.
This can be caused by an issue with Dreamweaver's memory management, dreamweaver some times does not do a great job managing memory and can cause CSS SCulptor to crash.
To work around, periodically save your design and select to save it as a preset, the next ti,me you open CSS SCulptor, you select the preset that you saved, then continue making modifications.
