Long Description not showing on Details page.
Thread began 9/03/2012 12:14 pm by willo009412397 | Last modified 9/04/2012 2:36 pm by Jason Byrnes | 653 views | 3 replies |
willo009412397
Hi
I have 2 problems i hope its ok to place them both here together, as there Dataassist related.
On my Details Page the Long Description is not showing?
And on my Update page everything updates but not the Image. Thanks for your help.
Regards Karl
DetailsPage.zip
I dont see why the long description would not show on the details page unless the column is empty in the database, the code to show it is on the page.
double check that the long description column is being populated in the data base.
to troubleshoot the issue with the image upload, I'll need to make a few changes to the update page to gather some information
1) add the following code at line 1:
error_reporting
(E_ALL);
2) change the redirect URL:
$WA_redirectURL = "Adminproducts_Results.php";
//$WA_redirectURL = "Adminproducts_Results.php";
$WA_redirectURL = "";
3) add the following code just before the </html> tag, this will show the update SQL:
<?php echo("SQL: ".$WA_Sql.""); ?>
4) On the bindings panel, expand the WA UPloaded FDiles global Status group and add the Debug info binding to the page.
send the results after testing a new update with an upload.
willo009412397
Hi Jason
Thankyou for your help, i have added the code but i dunno if i have done it right? When i open the page i have this code shown below, it pushes my header down the page and has this:
Notice: Undefined variable: WA_Sql in C:\xampp\htdocs\PrintingColourUK.Com\Templates\Adminproducts_Update.php on line 120
SQL: Status object: WA_UploadResult1
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
Then if i try an Image Uplaod i get this:
SQL: UPDATE `products` SET `ProductName` = 'A5 Flyer (148 x 210mm)', `ProductPrice` = 24.99, `ProductShortDesc` = 'Our high quality promotional flyers are printed in full colour (CMYK) including Digital Photograph. Printed Full Colour on 135gsm Gloss Art Paper.', `ProductLongDesc` = 'Our high quality promotional flyers are printed in full colour (CMYK) including Digital Photograph. Printed Full Colour on 135gsm Gloss Art Paper.', `ProductImage` = 'A4_Flyer.jpg' WHERE `ProductID`=1Status object: WA_UploadResult1
statusCode : 1
errorMessage :
clientFileName : A4_Flyer.jpg
fileExtension : jpg
serverFileName : A4_Flyer.jpg
serverSimpleFileName : A4_Flyer
serverDirectory : C:\xampp\htdocs\PrintingColourUK.Com\Templates\..\Shop\ShopImages\
contentType : image/jpeg
fileWasOverwritten : 1
fileWasSkipped :
fileWasRenamed :
fileSize : 9723
isImage : 1
imageWidth : 180
imageHeight : 230
WA_UploadResult1_1:
fileExtension : jpg
fileSize : 9723
imageWidth : 180
imageHeight : 230
isImage : 1
fileWasSkipped :
fileWasRenamed :
statusCode : 1
I have attached copy of Upload.php for you in-case i have added the code wrong.
Regards Karl
Results_Page.zip
according to this:
the image name is being added to the updated record correctly:
