Data Assist
Hello, I am new to this software and need some guidance on how to set up a simple database driven catalouge site.
Ive tried but keep getting these following errors:
"Warning: require_once(webassist/form_validations/wavt_scripts_php.php) [function.require-once]: failed to open stream: No such file or directory in /homepages/13/d373921062/htdocs/products_results.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'webassist/form_validations/wavt_scripts_php.php' (include_path='.:/usr/lib/php5') in /homepages/13/d373921062/htdocs/products_results.php on line 1"
I created a connection which when tested was OK, I then went on to create a new page using the catalouge template, uploaded it but the above errors showed. Maybe I need to add tables to the database manually, and if so, how?
I was under the impression that I simple wizard would make the whole process a painless affair.
Would really appreciate some guidance.
James
