CSS Menu Writer & DW CS6
Is CSS Menu Writer compatible with Dreamweaver CS6?
Or do I have to purchase Design Extender?
CSS Menu writer is not compatible with DW CS6 at this time, you will need to use it in a previous version of Dreamweaver, or you could upgrade to data Bridge which includes CSS menu writer and other extensions in a CS6 compatible package.
I do have Data Bridge, but don't see CSS Menu Writer in the extensions. I see that is included in Design Extender, but not prepared to spend $300 on the upgrade, as I don't require any of the other extensions in the package.
I'm sorry, you are right, it is not included in Data Bridge, it is included in Design Extender.
If you do not wish to upgrade to design extender, you will need to use CSS Menu Writer in a previous version of Dreamweaver that it is compatible with.
