Multiple -- Multiple deletes in spry tab
Thread began 8/28/2012 6:51 am by asarcona308398 | Last modified 8/28/2012 9:57 am by asarcona308398 | 1877 views | 4 replies |
asarcona308398
I have a problem involving multiple Multiple deletes in a spry tabbed panels page.
I have the form spread across all the tabs and even after re-locating the code, I can't seem to get it to work.
file attached
Thanks for your help
Tony
staffdetails_update.zip
asarcona308398
update
in looking at the form further, I've realized that the multiple -- Update Server behaviors that are on the page above the multiple deletes are now broken.
I didn't have a prior problem before the multiple deletes were added, as I check the server behaviors as I go.
asarcona308398
update
in the form action I removed the re-direct and the form returns to operational....
how can I re-direct to the desired page after the updates and deletions occur, if not in the form action"" parameter?
possibly in the last server behavior's "go to page" option???
Yes, that is where you specify the redirect.
asarcona308398
update
Thanks Jason, I'll give it a whirl! :-)
