Validation fail
Thread began 8/28/2012 4:24 am by marzio1348169 | Last modified 8/28/2012 12:05 pm by marzio1348169 | 564 views | 4 replies |
marzio1348169
Validation fail
Hello
I have a insert data page (Wizard DataAssist) and I applied a Server Validation for a field required.
When I submit without text in this field the system correctly remain in the page but strangely register the record in the database
Where is the problem?
no way to know without seeing the code. please send a copy of the page
marzio1348169
Here the file (not complete) the server validation is for Title
annunci_Insert.php.zip
the problem is code order.
The code to insert the record is at lines 5 - 26
the code to validate is at lines 38 - 52
This needs to be rearranged so the validation code block is before the insert code block.
marzio1348169
OK Thank You very much
