Two problems with SecurityAssist 2
Thread began 8/25/2012 5:26 pm by marzio1348169 | Last modified 8/30/2012 11:50 am by Jason Byrnes | 2136 views | 21 replies |
marzio1348169
Mac OSX Leopard Mountain, DW CS4, SecurityAssist 2 last version
SecurityAssist last extension installed
After create the pages, I have two problem:
1- userupdate.php page
the Country don't change (display always U.S.A. but in the DB is correct)
2- forgotpassword.php
Always this error "Your email address could not be found in our records. Please try again."
And also I would to eliminate the Answer Validation
Send a copy of the pages in question please.
marzio1348169
Here the pages
Files.zip
on the user update page, click the country select list in design view, then in the property inspector, click the dynamic button
in the select value equal to section, change the code from:
<?php (isset($_GET["invalid"])?ValidatedField("userupdate","User_Update_group_11_Country"):""?>
<?php (isset($_GET["invalid"])?ValidatedField("userupdate","User_Update_group_11_Country"):"".$row_SecurityAssistusers["UserCountry"].""?>
On the forgot password page, edit the forgot password server behavior, on the email settings tab, set the SMTP server and port.
marzio1348169
I config the email setting and smtp, but the problem is the same
need most recent copy of the page please.
marzio1348169
And now when I insert a new registration the first step is correct (register in DB and send email verification)
But when I click ok verification the system redirect to user_confirm page with this error:
Your verification link has expired. Visit your profile page to send a new link.
And in the database randomPassword is present, but emailVerified is 0
marzio1348169
Ok here the file
forgotpassword.php.zip
marzio1348169
I still have these problems:
- Forgopassword not find the email in the DB
- Registration with Validation Email
(Your verification link has expired. Visit your profile page to send a new link.)
the smtp server address and port you entered is not correct.
I have tried using telnet to create a connection to the server for testing, and the connection is failing. double check the smtp server and port settings that you are using.
for the verification link issue, i'll need to see the registration page, the email template file that generates the link and the confirmation page.
