Testing Server error
New computer and trying to re-install web assist extensions. Getting the attached error while trying to get existing site to connect to DB with new dreamweaver install.
This error means that in the site definition, you did not set the URL Prefix for the testing server to the correct URL to connect to your site.
Testing server url is same as previous installation that had no issues and connects successfully in manage sites Test Connection
what is the URL you used?
from the screen shot of the error, it looks like you used an IP address followed by /httpdocs
that is not correct.
