Images uploading with 640 permissions even with chmod applied
Thread began 8/22/2012 4:56 pm by sublucent | Last modified 8/22/2012 6:29 pm by sublucent | 940 views | 2 replies |
sublucentBeta Tester
Hello,
It seems that permissions are randomly set between 640 and 644 every time I upload an image to a Network Solutions site using File Manipulation. I have read in other posts that Network Solutions said it was the script that was causing the problems, not them.
I've applied the chmod() found in other posts:
WA_DFP_SetupUploadStatusStruct
("WA_UploadResult1");
if(isset(
$_POST["Insert"]) || isset($_POST["Insert_x"])){
chmod(WA_DFP_UploadFiles("WA_UploadResult1""image""0""""JPG:90"$WA_UploadResult1_Params), 0644);
Now it seems the first time I upload an image it sets permissions to 640, but if upload the same image a second time the permissions get set to 644.
EDIT: After further testing it still seems a bit random.
Any thoughts on how I can resolve this? Do I need to make any changes to the helperphp.php file?
Thanks in advance
instead of wrapping the chmod function around the upload code:
chmod(WA_DFP_UploadFiles("WA_UploadResult1", "image", "0", "", "JPG:90", $WA_UploadResult1_Params), 0644);
revert that line back to:
WA_DFP_UploadFiles("WA_UploadResult1", "image", "0", "", "JPG:90", $WA_UploadResult1_Params);
then add the following line to chmod the results:
chmod($WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]."".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"], 0644);
the upload code should look like this:
if(isset(
WA_DFP_UploadFiles("WA_UploadResult1""image""0""""JPG:90"$WA_UploadResult1_Params);
Thank you!
That did it!
Thank you and thanks for the fast response!
