Conditional Statements
Thread begun 8/20/2012 7:40 am by mouse426912 | Last modified 8/20/2012 10:42 am by mouse426912 | 1235 views | 2 replies |
mouse426912
I am doing a simple listing of 'specials' using dataAssit but cannot work out how to make this conditional clause happen: if (There are no results){echo"No specials available at this time.";}; Where does this go so it will work. How should the the if syntax be done? I've tried several arrangements to no avail. I am not new to php databases but am new to DataAssist.
I'm seeing in a post below the syntax to be used but I'm not understanding where to put it. I'm used to having my querys and conditionals/echo statements all in one place.
so if the recordset is empty, you want to show the message?
place your cursor after the repeat region on the page that will show the results, then type the message. Select it in design view, and on the Server Behaviors panel, click the plus button and select Show region -> Show If Recordset is empty
mouse426912
I love it! Thanks.
