What is the function of rel2abs()?
Thread begun 8/20/2012 6:24 am by msummers194171 | Last modified 8/21/2012 9:21 am by msummers194171 | 2477 views | 4 replies |
msummers194171
On any page that is redirecting after writing to a database, this code is inserted as part of the block that handles the database write -
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
Is that to make the redirection use an absolute link (as it should)?
header("Location: " . $whatever)
If so, it's not working for me. It always inserts some incomplete path that looks like $_SERVER['DOCUMENT_ROOT'] to me. It should be something beginning with "http://www.example.com/" shouldn't it? In most cases, my redirection is failing and I wind up just commenting out the block of code I put above.
Ian S
Is this happening to you when using the behaviour on a page with the Framework?
I have similar issues (but only on some sites).
Cheers
Ian
msummers194171
No - it's on plain pages created with DA2 or DB only.
msummers194171
Jason - I'll reply to this ticket today.
