workflow for adding to dataassist pages
Thread begun 8/17/2012 10:45 am by sfj6167 | Last modified 8/20/2012 10:13 am by sfj6167 | 1657 views | 4 replies |
sfj6167
Hi there
after creating administrative user pages with dataassist, I need to add some more fields to the pages.
Can dataassist make the fields needed on the pages for me ?
Whats the workflow for adding text field !
Whats the workflow for adding a dynamic menu/list !
best regards
Bison
the data assist wizard cant be used to add the new fields unless you delete the pages and recreate them.
if you saved the original settings as an application preset, you can select the preset, then make the changes to add the new fields.
if you wish to add the new fields manually, you will need update the insert record and update record behaviors to use them.
for the dynamic select list, you will also need to create the record set used to populate it.
sfj6167
Hi Jason
Thanks for the info, but when I try to create new pages and select a preset (administrative users), I cant chose any fields, that are non (standard) to that preset. The db fields presented is ONLY what is standard in that preset.
If I select a Blank preset, all db fields is selectable...
regards
bison
if you are using an application preset that was not originally created for your table, you will need to uncheck the Create table For Me option, select your table, then make adjustments on the manage pages tab by editing the Fields settings, and editing each of the pages to be created to use your tables columns.
sfj6167
Ok Thanks for the info
