ecart isnt generating check out pages
Thread began 8/17/2012 2:52 am by jamie424562 | Last modified 8/17/2012 7:45 am by Jason Byrnes | 424 views | 1 replies |
jamie424562
hi there
trying to create shop with ecart, latest version 5.06, have created cart and configured all.
using UPS for delivery and configuraing all settings needed.
when clickign finish window just closes and does nothing.
basicly its not generating the checkout pages.
have uninstalled and re-installed a few times now but having no luck.
DO also have data bridge and design extender,also latest versions.
erm help pls.
thanks in advance
when you installed eCart, data Bridge and design Exteder, was eCart the last one to be installed? It should _not_ be installed last, you should make sure to install either design extender or data bridge after installing eCart. I would recomend uninstalling eCart and data bridge, then Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
and reinstall eCart first, then Data Bridge.
in some cases, i have seen the checkout wizard stall on creating the checkout pages till you click into the eCart object widow,try clicking in the eCart object widow if you continue to have the problem.
