the INSERT is not insertable-into
Good afternoon,
In a Mysql table I have two fields which I need to concatenate to one field to create a path so that image paths can be found.
Fields are:
image1+imageDirectory concat to Fullpath
Fullpath
I am using a Navicat View and as a test used the code
select `boats`.`RecNo` AS `RecNo`,`boats`.`Manufacturer` AS `Manufacturer`,`boats`.`imagedirectory` AS `imagedirectory`,`boats`.`image1` AS `image1`,concat(`boats`.`imagedirectory`,`boats`.`image1`) AS `FullPath`,`boats`.`RegDate` AS `RegDate` from `boats` this seems to run correctly
In the data assist wizard I created a test insert page (zip attached) but when I try to insert I get an error
The target table fullpath_working2 of the INSERT is not insertable-into
It seems to indicate a View cannot be inserted into.
The View shows in DA Wizard Table List as a table.
Thanks for any help
John
