Where only in not NULL
Thread began 8/14/2012 8:09 pm by Cologne | Last modified 8/15/2012 12:23 pm by Jason Byrnes | 265 views | 1 replies |
Cologne
Hello,
I need some help with a SELECT
Its like
SELECT * FROM artist WHERE id=1 AND makeup = yes
The problem is makeup can be NULL and if its null the SELECT wont work.
I need to check IFNULL.
Like IF makeup NOTNULL then AND makup = yes
Can someone help me,
Cheers
Denis
I'm not sure I understand the question.
first off, yes is a string, so the query should be:
SELECT * FROM artist WHERE id=1 AND makeup = 'yes'
using makeup = 'yes' in the where clause will exclude records where NULL is used since NUll is not equal to yes
are you trying to return records where the makeup column contains either NULL or yes?
in that case:
SELECT * FROM artist WHERE id=1 AND (makeup = 'yes' OR makeup = NULL)
