How to display information in the order i chose to show it in..
Thread began 8/14/2012 12:46 pm by Paul | Last modified 8/16/2012 8:28 am by Jason Byrnes | 976 views | 3 replies |
Paul
I'm trying to change the way data is pulled through my site for example.
I have 10 blog entries
And i want to move one of them without having to delete all my data and re-imputing
the data above that entry. So i want to move entry 5 to spot 8.
Is there a way i can tweak the code to be able to sort by an id I assign to the post?
Please let me know.
Thanks!
-Issac
This is not supported in Power CMS BUilder and will require some custom development.
you would need to add a new column to the pcms2_contnet table to use for ordering purposes assign each content record a number value.
then the recordset that you use to display the content, add an order by clause.
If you need help implementing this custom change, I would suggest signing up for a premiere support appointment.
Paul
I submitted a ticket yesterday. How will you contact me through Email or phone??
The engineering team will give you a call to set the schedule for the appointment.
