HTML Editor 3.0.2 Please Wait Loading
Thread began 8/13/2012 4:35 pm by digitaldesign | Last modified 8/14/2012 3:02 pm by digitaldesign | 897 views | 2 replies |
digitaldesign
Hello,
I'm experiencing the same "Please Wait... Loading" on a new server that I do have admin access to change.
PHP & MySQL versions are over the minimum dot releases that are required.
Tried the Javascript edit on the index page and removed any extra line breaks in the configuration file.
Any assistance would be beneficial. Thanks in advance!
EDIT:
Windows IIS 6.0 Server with ISAPI PHP 5.2.4 and MySQL 5.0.45
GD Library version enabled bundled (2.0.34 compatible)
Safe mode is OFF
Cheers,
Monica
digitaldesign
Solved
This was solved on my server! Thanks guys!
For anyone else... check that the setup in the PHP.ini file for
magic_quotes_gpc
magic_quotes_runtime
They should both be set to "OFF" not "ON"
You can always check that by making a blank PHP page with this on it:
<?php echo phpinfo();?>
Hope that helps!
Cheers,
Monica
