DataAssist - query not showing up in bindings panel and producing errors when run
Thread began 8/13/2012 11:49 am by sandy170299 | Last modified 8/13/2012 12:44 pm by sandy170299 | 296 views | 4 replies |
sandy170299
This is the query in question (I have joined three tables to produce this query):
$colname_WADAemployeesxjobsxlaborcodes = "-1";
if (isset($_SESSION['employeeID'])) {
$colname_WADAemployeesxjobsxlaborcodes = $_SESSION['SecurityAssist_employeeID'];
mysql_select_db($database_timesheets, $timesheets);
$query_WADAemployeesxjobsxlaborcodes = "SELECT employeesxjobsxlaborcodes.ID, employeesxjobsxlaborcodes.employeeID, employeesxjobsxlaborcodes.laborCodeID, employeesxjobsxlaborcodes.jobID, employeesxjobsxlaborcodes.dateWorked, employeesxjobsxlaborcodes.housrWorked, jobs.jobDescription, laborcodes.laborCode
FROM (employeesxjobsxlaborcodes INNER JOIN jobs ON employeesxjobsxlaborcodes.jobID = jobs.jobID) INNER JOIN laborcodes ON employeesxjobsxlaborcodes.laborCodeID = laborcodes.laborCodeID WHERE employeeID = %";
$query_limit_WADAemployeesxjobsxlaborcodes = sprintf("%s LIMIT %d, %d", $query_WADAemployeesxjobsxlaborcodes, $startRow_WADAemployeesxjobsxlaborcodes, $maxRows_WADAemployeesxjobsxlaborcodes);
$WADAemployeesxjobsxlaborcodes = mysql_query($query_limit_WADAemployeesxjobsxlaborcodes, $timesheets) or die(mysql_error());
$row_WADAemployeesxjobsxlaborcodes = mysql_fetch_assoc($WADAemployeesxjobsxlaborcodes);
When I load the page, I get the following error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '% LIMIT 0, 10' at line 2
This is the code that is on line 2: <?php require_once("webassist/database_management/wa_appbuilder_php.php"); ?>
Thank you!
send a copy of the full page please so i can see the code in context.
sandy170299
Attached is the page.
employeesxjobsxlaborcodes_results.zip
i dont see the same code from your initial post on this page?
but the query in your initial post had the following at the End of the SQL:
that should have been:
WHERE employeeID = %s", GetSQLValueString($colname_WADAemployeesxjobsxlaborcodes, "int"));
in the page that you have sent though, it has the correct code.
sandy170299
I redid all of the pages and it seems to be working now. Thank you.
