Rollovers not working with framework or CSSWriter
Thread began 8/10/2012 10:21 pm by Steve | Last modified 8/16/2012 1:58 pm by Jason Byrnes | 666 views | 4 replies |
Steve
This is very confusing...
This page is the menu:
menu.php
This page is nothing but a blank page with the menu inserted as a Plugin from the Framework builder:
test2.php
Why would the DW simple rollover behavior work when isolated but not when in the environment of the plugin?
Note the rollovers are the on the top two graphics...
What version of design Extender are you using? I believe this issue should be fixed in the latest version 1.1.0, if you have a previous version, please uninstall it from the extension manager and install the newer one, you will need to recreate the plugin and upload the webassist/framework builder folder to the server correct the issue once you have the latest version installed.
Steve
I ended up recoding in CSS but would like to see the issue resolved.
Version 1.1.0 was installed after removing 1.0.9 yesterday.
I'll re-upload the Framework Builder folder so as to be able to confirm this solution.
Steve
retest - same failure
test2.php
I'll try loading the csswriter js file prior to the DW scripts to see if there is any merit in "order" of load.
